Fecking pushchairs
Old Jan 2, 2008 | 01:41 AM
Olliexr4x4's Avatar
Olliexr4x4
Default Fecking pushchairs
OK, maybe I am the only one with this problem. I (We) have had loads of pushchairs and we get flats all the time. Due to the dog walking we do and nasty paths we walk along our pushchairs always get flat tyres. The 3 wheelers are the best for us due to the terrain we have to walk across. Has anybody ever filled the tubes with tyre flat or expandable foam because that is what I am thinking of doing
Old Jan 2, 2008 | 06:39 AM
dojj's Avatar
dojj
Resident Wrestling Legend
would it not be easier to get wheels that aren't pneumatic?
or is this a posh chair that you can't really afford to replace because the wife would go bonkers?
how do you swap the tyres over when they go flat then?
is there a valve you can use the n flat tyre gunk in or not?
Old Jan 2, 2008 | 06:50 AM
Bungle's Avatar
Bungle
Use tyre gunk fella it worked for us, Just like a push bike dojj with tube inside and the same sort of valve
Old Jan 2, 2008 | 07:27 AM
Rolls's Avatar
Rolls
Got to any bike shop, and buy some "slime" - should do the trick...
Old Jan 2, 2008 | 07:30 AM
Slime is rubbish, use Ultraseal, on your car as well, been using it over 10 years now.
Old Jan 2, 2008 | 09:25 AM
Olliexr4x4's Avatar
Olliexr4x4
We have another stroller type pushchair but its no good for dog walkng (need one with bigger wheels for rougher ground). I will try some of this tyre gunk or ultraseal stuff, cheers
Old Jan 2, 2008 | 09:31 AM
wide ka's Avatar
wide ka
try fitting small kids bike tyres to it too, they are alot thicker than the crap they fit noramly to the pushchairs, and use slime, thats what we do at work
Jim Galbally
59
Mar 21, 2005 06:54 PM
apples24
16
Nov 30, 2004 08:37 PM
Kev.H
18
Oct 14, 2004 09:30 PM
Nath
Aug 26, 2004 09:17 PM
Nath
12
Aug 6, 2004 12:05 PM
