blue ford leads and a couple of other bits
ok, no wive gone coil pack i have a couple of things i dont need
blue ford motorsport leads, covered less than 1k
£45 SOLD
ignition amp and heat sink £10 i have 2 of these
4wd prop shaft doughnut, no cracks £30
4wd fuel pump sender unit, n working order, kept as a spare £15
4wd cossie engine loom, full loom, earth has been moved so it goes to battery but can be taped back up to where it should be, and amal valve wires extended to inner wing under air filter
this is an aircon model loom, but if not using aircon then just simply hide the wires ike i did
not needed as had a custom loom off ryan now
£70
postage will be extra but not alot,it will be 1st class recorded aswell, unless you pay for special
£45 SOLD
£70
kosienutter
31
Aug 22, 2015 09:55 AM
