rebuilt complete cosworth engine with turbo Any offers????
my mate is thinking of breaking his 2wd saph, if he can sell the engine first
heres the spec
200 block
mahle pistons with valve cut outs, std comp
T34 with 63 housing from turbo technics (brand new)
arp stud and nut kit
arp con rod bolts
new high pressure pump
new crank sensor
new phase sensor
new dizzy cap and rotor arm
new air temp sensor
new water temp sensor
new bottom pulley
block skimmed
crank polished
new oil pick up pipe
skimmed flywheel
82 degree thermostat
new water pump
geniune ford bearings std size
cometic multi layer headgasket
cometic inlet gasket
standard 4x4 head
new lifters
minuimul skim
pressure tested
new style piper vernier pulleys
new cambelt and tensioner
new ford gaskets through out
comes with inlet, dizzy
blue motorsport leads
ford 071 plugs
also comes with greys and msd chip to suit the engine spec
has covered 1500 miles since having a full rebuild which a 1000 was running in miles
can be heard running as its all still in the car at the moment, the only reason he's thinking of breaking it is because the car has been paint strippered
has got all the reciepts for all the new engine parts aswell
NOW HAS BRAND NEW T34 ON THE ENGINE
heres the spec
200 block
arp con rod bolts
new crank sensor
new phase sensor
new air temp sensor
new bottom pulley
block skimmed
crank polished
skimmed flywheel
new water pump
standard 4x4 head
new lifters
minuimul skim
pressure tested
ford 071 plugs
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
