Gearbox oil in the diff, recommended, any damage or ok?
Old Dec 30, 2007 | 05:29 PM
Mr C's Avatar
Mr C
Default Gearbox oil in the diff, recommended, any damage or ok?
Is gearbox and diff fluid similar or they totally different properties?
I have a lot of oil for my T5 G.box and I have a welded rear diff, while I dont want any dameage to occur too the diff wheels would it be OK to use a litre of left over box oil in my diff or just spend the extra£7 on proper diff fluid?
Regards- tight *swear word* Mark
Old Dec 30, 2007 | 05:31 PM
Alvyn's Avatar
Alvyn
in a word NO dont use it!
Old Dec 30, 2007 | 05:35 PM
dave cos4x4's Avatar
dave cos4x4
as above.
Old Dec 31, 2007 | 08:19 AM
As the diff is WELDED perfectly fine to use, lsd oil is totally different, gear oils are fine.
Old Dec 31, 2007 | 08:24 AM
big_wig_074's Avatar
big_wig_074
id bung it in,its a welder!
Old Dec 31, 2007 | 10:35 AM
Mr C's Avatar
Mr C
err a mixture of opinions there? I know there is no diff plates to protect but is gear oil anywhere near the same as a diff oil? I have no idea
Old Dec 31, 2007 | 10:43 AM
dave cos4x4
Mr C
how much does the rear diff hold....1-2 litres.
£10-£20 max for proper diff oil.....its up to you.
Old Dec 31, 2007 | 10:44 AM
Graceland's Avatar
Graceland
Team HOTHOT!
At the end of the day its an open diff that you welded up - stick any old gearbox oil in and it will be fine
Old Dec 31, 2007 | 04:25 PM
Gearbox oil and diff oil, (for non LSD's) are just made to withstand shearing and messhing forces.
If in doubt phone up oilman 01209 215164.
Old Jan 2, 2008 | 10:24 AM
Mr C's Avatar
Mr C
I decided on the proper stuff, it holds just 1.2 litre max Dave , after buying diff oil and comparing the two- box and diff oil are nowhere near the same, I would say box oil is like water compared to the diff stuff so yes I spent the cash- all £6.99 of it
Old Jan 2, 2008 | 10:25 AM
Mr C's Avatar
Mr C
I get what your saying Graceland, welded diff is cheap to replace after all, just hate doing stuff twice if not needed
RSBryden
Sep 6, 2015 08:39 PM
gingeRS
Sep 4, 2015 06:29 PM
rog
Sep 4, 2015 07:24 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
