manifold studs
Old Dec 29, 2007 | 04:36 PM
Maxiboy's Avatar
Maxiboy
Default manifold studs
can you get a manifold stud which is m10 course on one end and m10 fine on the other.
with the fine thread the longer end...
Old Dec 29, 2007 | 04:40 PM
MK5RST's Avatar
MK5RST
I think most studs are like that..... Course thread screws into head and fine of for your nut...?
Old Dec 29, 2007 | 04:52 PM
Maxiboy's Avatar
Maxiboy
well i,ve only found m10 course or m10 fine on both ends. haven,t been able to find a mixed thread one yet. any ideas what there fitted to as standard mate.
Old Dec 29, 2007 | 05:17 PM
MK5RST's Avatar
MK5RST
How many do you need? im sure ive got a couple
maxrs16's Avatar
maxrs16
webber twin carb manifolds have them sort of bolts burton sells them
Old Dec 29, 2007 | 05:19 PM
MK5RST's Avatar
MK5RST
That will be where ive seen them before and explain why ive got some somewhere in my box of bolts
Old Dec 29, 2007 | 05:22 PM
MK5RST's Avatar
MK5RST
https://www.burtonpower.com/product_...px?CCode=PC800
Old Dec 29, 2007 | 05:48 PM
Maxiboy's Avatar
Maxiboy
hi mate thanks. i need four if you have them.
the webber ones are 5/16 or m8 from what i can see. i need m10
thanks for your help though.
Old Dec 29, 2007 | 07:40 PM
Very common fitting, used on cossie heads amongst others.
Matt Lewis sells them as well, 01922 692424.
Old Dec 30, 2007 | 11:52 AM
Maxiboy's Avatar
Maxiboy
cheers mate thanks.
will try him wednesday
jessie_rs
62
Aug 6, 2019 09:27 PM
Cosnada
Jan 7, 2016 05:30 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
caprixpack
Sep 25, 2015 07:53 PM
