trailer / towing test
Old Dec 29, 2007 | 10:42 AM
fraser9764's Avatar
fraser9764
Default trailer / towing test
has anyone done one?
i presume it is needed for towing a car on a twin axeled trailer?
just had a quick look on he dvla website and, as with any information about towing weights etc. its pretty vague.
i only passed my test in 06 so its not a freebie with your normal license, 97 was the cut off.
if it makes any difference the towing veicle will more than likley be a disco 2.5 tdi
Old Dec 29, 2007 | 03:46 PM
I think anything over 75kg needs a test with the after 97 license.
Most likely be better to ask a traffic cop, some forces even have an advice line, Norfolk does 01953 424242.
Old Dec 29, 2007 | 03:49 PM
gkandr4ch's Avatar
gkandr4ch
Test??? I tow a trailer every day although it is only a single wheel each side. I passed in 1998 - I am getting worried now!!
Old Dec 29, 2007 | 03:57 PM
MAD EVO 4's Avatar
MAD EVO 4
yep I had to do a test jan last yr for my to tow cars
you have to phone your local dvla centre and ask for the info but it can be an intense test whichlast for an hour
Old Dec 29, 2007 | 04:18 PM
glancy2081's Avatar
glancy2081
if you passed after 97 you can only tow up to 750kg gross weight
Old Dec 29, 2007 | 07:44 PM
I knew it had a 7 and a 5 in it.
Old Dec 29, 2007 | 07:46 PM
glancy2081's Avatar
glancy2081
a thought you just missed the 0 out close
Old Dec 29, 2007 | 07:47 PM
MAD EVO 4's Avatar
MAD EVO 4
that weight also includes the weight of the trailer as I found out
Old Dec 29, 2007 | 07:49 PM
glancy2081's Avatar
glancy2081
yes trailier and load to be no more than 750kg most cops have no idea of the law on this to tell the truth
Old Dec 29, 2007 | 07:50 PM
gkandr4ch's Avatar
gkandr4ch
Thats good then. My trailer is 8 x 4 and definately don't weigh that much.
Old Dec 29, 2007 | 07:51 PM
scottbrown's Avatar
scottbrown
So if you are towing a trailer and have the later licence then you do need B+E, if it is over 750kg including the trl.
Also bear in mind that you max train is 3.5t plus your 750kg towing on a newer licence.
If you are towing cars you will almost certainly need the +E entitlement.
Old Dec 29, 2007 | 07:54 PM
rssteve's Avatar
rssteve
how much does it cost to do the extra test? whats involved?
Old Dec 29, 2007 | 08:03 PM
MAD EVO 4's Avatar
MAD EVO 4
it cost me £80
you have to tow a box tralier which is wider then the towing vehicle so you have to use mirror extensions.
You have to do :-
Reverse test
brake test
drive around a town for about 40 mins, which will include you pulling over to the side of the rd where safe to do so, with the edge of the trailer over the kerb but the trailer wheels not touching the kerb.
Old Dec 29, 2007 | 08:06 PM
col cos1's Avatar
col cos1
so what happens if you passed your test in 97 but been banned a few times?
Old Dec 29, 2007 | 08:07 PM
Ginge !'s Avatar
Ginge !
just finding my feet
and whats the fine if you aint got one
Old Dec 29, 2007 | 08:10 PM
XRdodgybird's Avatar
XRdodgybird
Praise the XR!
Originally Posted by MAD EVO 4
it cost me £80
You have to do :-
Reverse test
brake test
Glad I passed in 1989.... Have never used my "grandfather rights" to tow anything but am sure I will one day. Test sounds quite hard but well worth every penny I am sure.
tankybaby66
Feb 6, 2016 02:24 PM
AJC
Oct 1, 2015 06:47 PM
pabloXR
Sep 21, 2015 12:42 PM
Cos500
Sep 16, 2015 09:50 PM
