Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Fuel pump not working
Old Dec 28, 2007 | 03:07 PM
trev27's Avatar
trev27
Default Fuel pump not working
Car not running, no priming at fuel pump. Checked wires there are 4, orange and Violet, White and 2 blacks earth.
The White has 9 volts going through it and the O/V wire has nothing, with the ignition key in. Is this right??
Thought that the O/V wire would have a permament live!!! Also the fuel gauge is not giving a reading eevn though
there is petrol in the car (it is well below the empty mark and does n't move). Everything else is ok on the car, it turns over
PATS appears to be fine and all electrics are working, thee is a spark at the spark plug.
Cheers for any help.
Old Jan 23, 2008 | 09:23 PM
RST Ski's Avatar
RST Ski
Did you sort it?
what car is it on? some cars dont prime the fuel pump when first turned on
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
