Identify Pistons Cosworth
Old Jan 26, 2004 | 08:00 PM
Default Identify Pistons Cosworth
Could anyone identify the pistons in the pics
They were removed from a 200 block
Mahle pistons
Under the piston it has 90P44W2+
On the top it has sp0,05 91,775
Is it possible to tell if they are Low Comp/ Standard and what size are they?????
Any help would be great
Thanks
http://img4.photobucket.com/albums/1...l/f4777e22.jpg
http://img4.photobucket.com/albums/1...l/aed1a43a.jpg
Old Jan 26, 2004 | 10:03 PM
Toe Knee's Avatar
Toe Knee
They look like Low Comp ones too me mate!
Old Jan 26, 2004 | 10:52 PM
richm's Avatar
richm
definitely low compression from the size of the bowl, 1mm oversize.
Old Jan 27, 2004 | 06:49 PM
How do you know they are 1mil over size ????
Any idea of the compression ratio or does that need to be measured?
I need std size for my car, can the pistons be bought like this or have they been machined
Thanks
Old Jan 27, 2004 | 09:50 PM
richm's Avatar
richm
91.775 will be the piston size - 1mm larger than standard bore..
sorry can't help on identifying the exact CR, but the bowl is certainly way bigger than standard. I believe Mahle make low CR pistons like this, although not 100% certain .. You may want to consider genuine Cosworth Racing pistons with low CR, I don't think the price difference is great.
Old Jan 28, 2004 | 06:25 PM
Rich in your opinion you would say the low comp Cosworth Racing pistons would be a better bet than the Mahle items.
Thanks
Old Jan 28, 2004 | 06:29 PM
richm's Avatar
richm
for what my opinion's worth, yes.. but you'd be better getting the view of people who have used both..
Cosworth quality is second to none, and generally regarded to be the best pistons available.
Old Jan 28, 2004 | 06:32 PM
Thank Rich !!
Anyone else care to share past experience in low comp pistons !!!!???
COSWORTH RACING OR MAHLE ????????
Answers on a postcard
Thanks
Old Jan 28, 2004 | 07:05 PM
Do all low comps have valve cut outs like the ones i have ????
JK12
33
Apr 26, 2021 12:09 PM
cossie09
Oct 11, 2015 06:29 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
