mt75 blow up
anyone know what actually happens?
from other peeps posts it normally happens in 2nd or third but what DOES actually happen.
1) does the box lock up completely and the car spin etc
2) can ya drive home
cheers + big up to ima for getting his fingers in there with the mapping
usually strips 3rd gear on higher power cars i have done that myself. not too sure on what will wear etc
put a big up post for the goon as its a bit off topic on your post
Originally Posted by nor_cossie
When all my boxes have gone I have always had 4 gear to go home with...
And it has happend 5 times
If it will only drive in 4th, it means you have stripped the input pair of gears.
That is, the input shaft drive teeth, and the matching teeth on the laygear
SMILER258
Sep 28, 2015 09:04 AM
mk1focus
Ford Fiesta
Sep 24, 2015 06:19 PM
