MK4 Escort Rev Counter Fitting ::HELP::
Old Jan 26, 2004 | 05:14 PM
Default MK4 Escort Rev Counter Fitting ::HELP::
alright guys im learin to drive at the mo but have a 3dr escort mk4 but doesnt have a rev counter, i have another dash/cluster to swap over that does have a rev counter, my question is how hard is the swap guna be and how do i wire the rev counter up?
any help appreciated snOOpy
Old Jan 27, 2004 | 09:41 AM
you have to run a wire from your coil to the rev counter. the coil should have a black, wire and a green wire coming from it. wire it to the green side.
Old Jan 28, 2004 | 05:21 PM
ok, so green wire to the plug on the inside of the arch
and the black wire goes to the coil yea?
Old Jan 28, 2004 | 07:32 PM
any 1 know if this guide is any help?
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=51448
Old Jan 29, 2004 | 04:56 PM
any1 got any ideas? i wanna do it this weekend
Old Jan 30, 2004 | 11:32 AM
basically the same as that guide m8. just run another green wire from the coil to the rev counter.
Old Feb 1, 2004 | 12:19 PM
you proberly have a coil pack get your new cluster and its plug join all the wires from your old dash plug to the new cluster leaving you with just a green wire then take it through the bulk head and wire it up to green wire in you amp {near side wing} you can chose either to green wires as they are the both the same
A.t.p
Aug 15, 2015 11:37 AM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
fatboy billy
Aug 3, 2015 08:34 AM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
