Any cossy experts!
Need to get a new headgasket on my car but my head could be warped aswell
could i just get it skimmed or do i have to get a new one so not to fook about with my compression ratio(its low comp)
You can always use the thicker metal comectic headgasket (as long as your block isn't wire rung) to drop the compression but i would get someone who knows what their doing to measure the head & the compressed thickness of the cometic gasket to work out the comp ratio.
Simon.
Simon.
Result
the reason i think ive got a problem with the head is graham goode think that coopers rings are decent, and my car had a new gasket last year so they think my heads gone soft
or was it that im soft in the head
Ill get ypur head off tomorrow jon c what has gone wrong (off your car i mean)!
I will also cheak head c if its like a nana!
Any one one here know what the max is for skimming ?
I was told once aslong as the surface is no lower than the end of the exhanst stud?
That sounds a bit of a rough guide to i would rather cheak it properly.
If to much is skimmed off is there a chance of valves toutching pistons?
Suppose thats a daft question it has Big valve cut outs in pistons
PassionFords Creator
138.68mm is the allowable depth.
Bear in mind that really big power motors should really just throw the head away if badly bowed and use a new one for fear of snapping camshafts in half and smashing your expensive internals up.
Cheers stu Head is now off gonna send the head,cams,ect away to be checked over by the pros just dont know who
need to find out what cams its got because the numbers on the ends dont make no sense its also got solid lifters
any ideas stu
Apparently there piper cams, but they dont say bd14 or bd15 theyve just got 3 or 4 numbers on the end so it looks like whoever does my head may have to send them back to piper to find out
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
