very low biting point
Old Dec 13, 2007 | 07:38 PM
jattman_ama's Avatar
jattman_ama
Default very low biting point
hi there, i have a diesel gearbox fitted to my fiesta and to change the gear you have to put your foot into the carpet and the biting point is just as low, could the clutch be gone? an the speedo decides to drop every so often, any ideas
Old Dec 14, 2007 | 12:03 AM
jayRS's Avatar
jayRS
sounds like yuo need to reset the rachet and let it re set it self
Old Dec 14, 2007 | 01:58 PM
ram's Avatar
ram
Has a large member
my old escort rst was like this wen i bought it. i just replaced the clutch cable and it was fine. must have been a stretched cable, might be the same for yours?
Old Dec 15, 2007 | 12:17 PM
mikee_rs's Avatar
mikee_rs
how do u do that jay??
Old Dec 15, 2007 | 08:55 PM
jayRS's Avatar
jayRS
your have to get ys finger up the back of the pedal and push the arm up and get the quadrant round and them let the rachet arm down again, push on the cluch a couple of times, slow and easy, dont boot it to the floor, and let it set it self, if the rachet it self has worn teeth it will slip back round and make no diffance.
im not saying this will sort the problem but it has for me before in the past on one of my first fiestas as well as a couple of mates fiestas, other times ive had to replace it, its worth a shot at least
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Tank Mike
Sep 26, 2015 08:07 AM
