Esc Cos Oil leak found :cry: CV Boot??
Old Oct 11, 2004 | 08:31 AM
DaveEscos's Avatar
DaveEscos
Default Esc Cos Oil leak found :cry: CV Boot??
The Drivers side drive shaft as it connects to the box, is sheathed with a rubber boot held with Metal circlips
well this has completley torn
thing is, what oil should come out? engine or box oil? from this. Also is it called the CV boot?
lastly.. where can i get one asap other than nobby fords
cheers
Old Oct 11, 2004 | 08:51 AM
Kevin Sharp's Avatar
Kevin Sharp
its not connected to the box its the front diff
the only thing you will lose is the cv grease
cv boot yes
best buy an oe ford one as they are better quality than crappy copys you gripppy cooont
Old Oct 11, 2004 | 08:58 AM
DOO's Avatar
DOO
dave finns codes for cv boot kit comes with clips and grease
inner cv boot kit 6672258 Ł19.62 +vat
outer cv boot kit 6672257 Ł21.34 +vat
Old Oct 11, 2004 | 09:10 AM
DaveEscos's Avatar
DaveEscos
cheers Doo (and Kev McUgly)
Should the grease be runny? as it literally poured out like fresh engine oil (only black)
i take it to replace, is shock out, hub down, driveshaft out?
Old Oct 11, 2004 | 12:30 PM
DaveEscos's Avatar
DaveEscos
boiinng
Old Oct 11, 2004 | 02:39 PM
St3V3_C's Avatar
St3V3_C
It will probably have a clip on the end of the shaft that is in the diff - need to take the bottom plate off the diff.
I am pretty sure you can only split the shaft at the wheel end, so to get the inner one on, you will have to take off the outer one first. there is then a circlip inside the outer cv joint that will let you take that off the shaft.
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
st220kyle
16
Aug 14, 2015 06:13 AM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
mattman1234
24
Aug 1, 2015 11:46 AM
