FIESTA SI
Old Nov 30, 2007 | 07:53 PM
sierramad's Avatar
sierramad
Default FIESTA SI
hello ppl ive been buyin again ive just bought this fiesta si for 50 quid with only 68,000 on the clock, but it needs a clutch its not slipping yet but very high.Its a 1.6 zetec does anybody no what they are like to do as ive been told there not so easy to do. Any advice would be gr8
Old Dec 1, 2007 | 09:17 AM
cossieDavedree's Avatar
cossieDavedree
or a 168,000. lol
Ok well I don't know if it's hydraulic on an m plate, but my s reg diesel van is hydraulic, My 5th gear went on my box so whilst it was out i put in a new clutch. My clutch pedal is still high tho, and so is my friends zetec s that we did.
Check the cranshaft seals when u get the box out too.
Old Dec 1, 2007 | 09:18 AM
cossieDavedree
it's not that hard a job though.
Old Dec 2, 2007 | 12:25 PM
sierramad's Avatar
sierramad
Haha wouldnt suprise me if it was 168,000 lol mind you it does run like a dream so it might be genuine thanks for the advice mate . chris
Old Dec 4, 2007 | 08:32 AM
zippyobrien's Avatar
zippyobrien
its cable, me and a mate done mine in 5 hours with no engine crane,
get a haynes and have a go.
stick a jack under the engine,
pop the front ball joints and track rod ends, pop the shafts out, starter motor of, move egr over, undo the engine to tranny bolts, (think theres 8) undo the snti roll bar, (its an 18 mm socket so make sure you have one,
then drop the box when you undo the craddle, i just wobbled mine out lol
your cars the same colour as mine aswell lol, do the inside of your front tyres where stupidly quick ?
Old Dec 4, 2007 | 05:12 PM
sierramad's Avatar
sierramad
no the tyres on mine are really good but ive not had it long and ime not using it sounds like the tracking that on yours?. chris
Old Dec 15, 2007 | 09:34 PM
Mark_'s Avatar
Mark_
my rs2000 wears on the inside and thats down too tracking. every time i get it done it just goes again after a few hundred miles, also check the lower arms if they are worn it will be impossible to get tracked up properly
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
