Oil Temperture Sender
Old Nov 29, 2007 | 08:17 PM
jpbaginski's Avatar
jpbaginski
Default Oil Temperture Sender
On a 4x4 saph cos where would be the best place on the engine to connect the oil temp sender.
I allready have an oil pressure gauge with the sender coming of the adapter with the original oil pressure switch.
Thanks...
Old Nov 29, 2007 | 11:00 PM
Karl 3dr's Avatar
Karl 3dr
I need to know this too!
Old Nov 29, 2007 | 11:14 PM
Moonstone Mart's Avatar
Moonstone Mart
I fitted my oil temp sensor into the side of my sump. It is off the car at the mo which made it easier.
You can get fittings that screw into the sump plug hole and the sensor then screws into that.
Mart.
Old Nov 29, 2007 | 11:16 PM
Karl 3dr's Avatar
Karl 3dr
Where did you get the fittings from?
I've got the sender, just need some way of fitting it? lol
Karl
Old Nov 29, 2007 | 11:28 PM
Moonstone Mart
I didnt use any fittings, i tapped a thread into the side of the sump.
Im not sure where you get the sump plug/sender bung thing though sorry. Prob BURTONPOWER/DEMONTWEEKS maybe?
Mart.
Old Nov 29, 2007 | 11:31 PM
S3an's Avatar
S3an
just get a new sump plug approx Ł2 from ford and tap it the right thread size. it will only be a npt size.
Old Nov 29, 2007 | 11:36 PM
Karl 3dr's Avatar
Karl 3dr
Mart.
Have you got any pics mate?
Old Nov 30, 2007 | 08:19 AM
AlexD's Avatar
AlexD
Post Miester !
http://www.demon-tweeks.co.uk/produc...code=GLOFSPM14
Use this m8, i had it on the saph and going to have it on the escos too
Just replaces the sump plug, works fine..
Old Nov 30, 2007 | 09:21 AM
S3an's Avatar
S3an
Originally Posted by AlexD
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=GLOFSPM14
or do what i said and buy one for a couple of quid and get some one to drill and tap it
Old Nov 30, 2007 | 10:27 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
as said,sump plug,
Old Nov 30, 2007 | 10:41 AM
MK5RST's Avatar
MK5RST
Burton power do a sump plug thats already tapped, about Ł5 i think
Old Nov 30, 2007 | 02:42 PM
Karl 3dr's Avatar
Karl 3dr
Cheers mate!!
Old Nov 30, 2007 | 06:38 PM
jpbaginski's Avatar
jpbaginski
Thanks for all the help!!!!
Thanks Again...............
Old Nov 30, 2007 | 07:32 PM
Miller 3's Avatar
Miller 3
How about this
CLICKY
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
