8.5 compression rate for 2wd Saph! (on 803's)
Hi,
my new rebuild block comes on a compression rate of 8.5 to 1
Can i run on 803's without problems??
And are there cometic multi layer headgaskets with a compressed thickness more than 0.7 mm??
Thanks allready,
Martijn
Thanks allready,
Martijn
Re the CR, I say yes....
Providing, you run it on high quality high octane fuel and have it live mapped properly.
There may be an upper boost limit lower than normal but than highly depends
on the rest of the engine and components, turbo etc...
Originally Posted by mechanic28
mine is near standard c/r run 30psi spike tailing to 27psi midrange down to 23psi at 7k rev limiter so yes but as said live map a must
Standard CR is 8.0:1 not 8.5:1
9:1 would be ok on greens but you defo need a live map for it
i would trust on ofthe shelf with comp that high
if you did buy an off the shelf chip for it with 8.5.1 comp the turbo exhaust housing might start glowing on tickover
waste of time bogging it mate it will only end in tears
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
dojj
28
Sep 11, 2015 10:00 PM
