Efi loom conversion question (RELAYS)
Old Oct 9, 2004 | 07:29 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default Efi loom conversion question (RELAYS)
Ok i know you need 3 relays to connect the efi oom to car loom what kind of relays are they cos shop didint know??
i have a spare orion 1600i here wil that have the relays i want on there anywere i can pinch??
Old Oct 9, 2004 | 07:39 PM
Katie's Avatar
Katie
I used three 40amp rated 12v automotive relays, most places sell them.
Old Oct 9, 2004 | 09:20 PM
Roosie's Avatar
Roosie
do u get these on a normal car anywere saves me buying them
Old Oct 9, 2004 | 09:25 PM
L33 BYT's Avatar
L33 BYT
I think I got the relay you need. Were from Paul when I got a load of bits linked with his/your rs.
What setup you running in Project Roosie? Is it the 2.1 or just EFI as I noticed your not using the 16v head???
Old Oct 10, 2004 | 09:30 AM
Roosie's Avatar
Roosie
just a low comp 1600 at min mate
i need 3 of them relays how much u want for them?
Old Oct 10, 2004 | 09:41 AM
L33 BYT's Avatar
L33 BYT
If i hunt em out you can have em mate.
Old Oct 10, 2004 | 09:42 AM
Roosie's Avatar
Roosie
cheers mate its fairly urgent
Old Oct 10, 2004 | 05:24 PM
Rolls's Avatar
Rolls
i used 2 for the fuel pump, one for the twin fan set-up, and one for all of the extra switched lives. In theroy you could do it with 2- there just normal 4 pin swithcing relays!
Old Oct 10, 2004 | 05:33 PM
smartrs's Avatar
smartrs
i picked up the relays up from autozone in newmarket ! there easyly found jus make sure you get the right rated ones
Old Oct 10, 2004 | 05:53 PM
Roosie's Avatar
Roosie
ok cheers guys maybe i just asked the wrong shop
Old Oct 10, 2004 | 05:57 PM
L33 BYT's Avatar
L33 BYT
Stu, Make sure you fuse all your live feeds mate. (Sorry if you already had)
The only reason I say that is when I did the Clifford on mine the relays they supplied were not suitable for the central locking system. I must have popped around 20 fuses.
DixieTheKid
11
Jun 6, 2020 11:20 AM
liamT74
Sep 23, 2015 10:24 PM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
