Possible fuel pump problems HELP PLEASE!!!!
Old Oct 9, 2004 | 05:17 PM
M7 COS's Avatar
M7 COS
Default Possible fuel pump problems HELP PLEASE!!!!
I have a Fiesta 1.6 Si (Zetec model)
A while ago I finished work and the car wouldn't start, I thought I'd run out of petrol, but I hadn't. When the RAC turned up he unscrewed the rear bench and wiggled the wire, something to do with the fuel pump/line. I then got the familiar buzzing sound and the car started fine. It's happened a few times since and I've just wiggled the wire and it's started. But now wiggling the wire doesn't do anything, there's no buzzing noise, I've checked the fuse and it's not blown, any ideas?
My cars stuck outside my house and cannot be towed, anybody a mobile mechanic or know a reputable one in the Essex area.
Your help in this matter is much appreciated.
Thanks
Old Oct 9, 2004 | 05:28 PM
murfs frst's Avatar
murfs frst
could be a loose wire in your sender/pump or the socket you plug into the top of your thank or a relay are you getting power to the pump .i had the same problem on my frst.it turned out to be the pump.good luck m8
Old Oct 9, 2004 | 05:31 PM
djskitzy's Avatar
djskitzy
You need a new fuel pump by the sound of things.... search on ebay, it's where I got mine.
Old Oct 9, 2004 | 05:33 PM
M7 COS's Avatar
M7 COS
Thanks guys
Is having a new fuel pump an expensive job?
Don't you have to remove the tank?
How can I get it to the garage?
Questions, questions!
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
