Building advice needed
Hi, I'm building a single skin brick garage in my garden, I've dug the trenches for the footings only 500mm deep as I didn't need building regs due to the fact it's only gonna be 28 sq/metres, now, if I'd of followed the councils guidelines/ building regs of 800mm it would of been alot more work. Is 500mm deep enough for a single skin wall, it's quite chalky soil with a bit of clay.
Cheers for any advice
Andy
Andy
I would advise you NOT to use a single skin for the foundations. Be better with a footing block OR normal 215x450x100mm breeze layed flat. A single skin isnt strong enough.
Yes 4:1 is fine, and it wants to be at least 175mm deep and 450mm wide.
what's a raft? Got a bricky coming to quote on Monday, How much approx do you reckon he'll charge to supply bricks and lintell and build the walls for a 5mx5.5m garage (ith 1x 1 1/2 size door and 1 side door supplied by me), and approx how much extra for a double skin? I know you'd have too see it normally but just an idea of Ł will do. Cheers for the advice so far, really appreciate it.
Andy
Andy
For one that size including bricks and a lintel, id say around 2.5k single skin. If less then result
A raft is where instead of digginf footings, you lay the actual base(floor) first, but the edges where the brickwork sits are thickened up. The floor should be 150mm, and the edges 200mm. Saves on digging too! Too late now tho lol!
Yes. If you fix a layer of dpm(damp proof membrane) like Visqueen(thick polythene) then batten clad over that, then plaster board it will be ok. I just painted inside of mine with sandtex fook plastering lol
Its just outdoor paint mate. Made it nice and bright in the garage, and is waterproof to a certain extent. That on, floor painted etc makes it all bright and dry.
Why would you want to plaster out the garage ????
JoeyBoyden
Jan 4, 2024 02:36 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
