how do you clean an idle control valve?
Remove the 2 screws and disconnect the wire on the top. The valve is normaly tight to pull out of the throttle body. I use brake cleaner first to get the crap out of then use wd40 or some service lube to lubricate the idle speed control valve.
Originally Posted by mr_intex
do you have to take it to bits?
or do you just disconnect, clean, oil and replace?
TPM961
Jan 15, 2018 10:50 AM
