good place to buy rs1800 oil pump for zt?
tried ford today and they want nearly £150, what other makes are there that are good and how much should i be looking at paying? cheers
why does it have to be an RS1800 pump?
thought all zetec oil pumps were the same.. infact im almost certain of it
so that kinda makes my question irrelavent, dont it
As Bri says, you can use a Renault 5 or Clio filter on a 2.0 pump, they are tiny.
Mondeo 1.8 are all the same as 2.0 iam 99% sure.
Just go to Ford, try asking for 1.8 Escort in case they tried adding RS tax
fords, £150 for a pump? i know nearly every engine part and nut and bolt are from ford but £150 is just a rip of, what good make pattern parts are there to go for?
Originally Posted by ©hatter Box
escort zetec oil pump is diffrent to an mondeo one people use the escort onces as there is less room
No as i was saying the mondeo pumps are all the same 1.8 or 2.0.
Escort 1.8 and Fiesta are the same and are angled down for clearance.
However you can use a 2.0 pump with a Renault oil filter.
things like an oil pump i would only buy a genuine one from fords yes you pay extra but its so an imporatnt that for me only the best will do.
thanks
sean
thanks
sean
mate i had this trouble trying to find anew one but to be honest i bought a second hand 1.8 escort one that had done over 100k miles and stripped it to find it was mint condition inside so you'll probably be ok to use secong hand one, just strip it first to make sure
big_Rad
Sep 15, 2017 09:36 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
adam151082
Aug 11, 2015 04:50 PM
