cosworth injector question
Old Nov 13, 2007 | 08:03 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Default cosworth injector question
ive been looking for some injectors for my stage 3 build, ive been told to have a look at siemens black injectors there apparently better than dark greens. anyway the ones ive seen are confusing me a bit some say low resistance some say high resistance. whats the difference and whats the ones to go for? high or low?
Old Nov 13, 2007 | 08:17 PM
GARETH T's Avatar
GARETH T
im assuming your still using a standard spec ecu not after market! you will need low impedance injectors!
are you planning on going for more power in the future? if the answer is no, i would just stick with 803's
Old Nov 13, 2007 | 08:35 PM
OrionRST200bhp
i plan to have more power eventually but i was just wondering what the difference was in the high and low resistance injectors?
Old Nov 13, 2007 | 09:47 PM
mechanic28's Avatar
mechanic28
buy my dark greens
Old Nov 13, 2007 | 09:58 PM
charlie luciano's Avatar
charlie luciano
As stated already if you are going for a stage 3 build and power just go for Bosch green 803's, when you are going for 400/500 horsies then look into super duper injectors,
Luciano
Old Nov 13, 2007 | 11:01 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
If you want High Impedance, I have some Siemens 60lb (610cc) Injectors (brand new) for sale!!
Old Nov 14, 2007 | 03:34 AM
Alan s1's Avatar
Alan s1
The Webber ecu use's LOW Impedance I have aset in my cossie (still not got it running yet tho ) Basicly as said only go for them if your looking for the 400mark Stu told me to go for the siemens 55lb (some thing like that ) "blacks" instead for Greys Theres alot of us on here running simlar specs IE T34 (how long it will last @ 27 odd psi is anyones guees tho ) "blacks" 500 cooler and a chip ect and figers i've heard are 380 to 410bhp Or to realy get the full protentusal (sp ) go for a T38 i realy want 1 but cash is not there to do so atm
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Aug 14, 2015 07:29 AM
Perfmr2
Aug 6, 2015 07:30 AM
