cosworth injector question
ive been looking for some injectors for my stage 3 build, ive been told to have a look at siemens black injectors there apparently better than dark greens. anyway the ones ive seen are confusing me a bit some say low resistance some say high resistance. whats the difference and whats the ones to go for? high or low? :?
im assuming your still using a standard spec ecu not after market! you will need low impedance injectors!
are you planning on going for more power in the future? if the answer is no, i would just stick with 803's :top: |
i plan to have more power eventually but i was just wondering what the difference was in the high and low resistance injectors?
buy my dark greens :top:
As stated already :top: if you are going for a stage 3 build and power just go for Bosch green 803's, when you are going for 400/500 horsies then look into super duper injectors, :top: :top:
Luciano |
If you want High Impedance, I have some Siemens 60lb (610cc) Injectors (brand new) for sale!! ;)
The Webber ecu use's LOW Impedance I have aset in my cossie ;) (still not got it running yet tho :cry: ) Basicly as said only go for them if your looking for the 400mark ;) Stu told me to go for the siemens 55lb (some thing like that :oops: ) "blacks" instead for Greys ;) Theres alot of us on here running simlar specs IE T34 (how long it will last @ 27 odd psi is anyones guees tho :cry: ) "blacks" 500 cooler and a chip ect and figers i've heard are 380 to 410bhp :top: :top: Or to realy get the full protentusal (sp :cry: ) go for a T38 ;) i realy want 1 but cash is not there to do so atm :(
© 2024 MH Sub I, LLC dba Internet Brands
