Autronic SM4 on YBG
Old Nov 12, 2007 | 06:03 PM
cos 404's Avatar
cos 404
Default Autronic SM4 on YBG
Hi guys,
I'd like to know if someone out there has fitted an autronic SM4 ecu on a nasty cossie, cause i have just bought one for my 4wd sapp cossie! and would like to know how your engines are doing! How about performance?
Reliability? keeping in mind that if you have the combination of these two, you must get it mapped my a mapping specialist!
Many thanks
Paul.
Old Nov 12, 2007 | 06:10 PM
rapidcossie's Avatar
rapidcossie
I run SM4 on mine and its pretty good
sure a few others do to
Old Nov 12, 2007 | 06:54 PM
Paul_RS's Avatar
Paul_RS
Niall.b off here has it as well. Fitted it himself as well. Seems a good system with silly amounts of inputs and outputs on it
Old Nov 12, 2007 | 07:24 PM
Cosworth Bassie's Avatar
Cosworth Bassie
It's a very good aftermarket stand alone ECU.
But, if you fit an Autronic system on an YB and you are using the std crank sensor en phase sensor, then you need to take off 2 lugs from the cranksensor....??? Always wondered why
Old Nov 12, 2007 | 07:38 PM
cos 404's Avatar
cos 404
Default atronic SM4 on ybg
2 lugs from the cranksensor? what does that mean? I read about autronic and find out that it can run reluctor type and hall effect crank sensor without any probs
Old Nov 12, 2007 | 07:42 PM
cos 404's Avatar
cos 404
Default aytronic SM4 on ybg
To all,
how much bhp does your cossie pack? what type of injectors do you run?
Are you running wasted spark? Also, what type of coil pack do use? I heard that the zetec one can produce a very good spark.
Old Nov 12, 2007 | 09:22 PM
Staffi's Avatar
Staffi
I have the SM4 on my saff, mapped by Mark @ MA developments
Really pleased with it, SO much smoother imo, i'm running 1000cc injectors 442bhp@ 27 psi..Anti-lag, launch control..
Old Nov 12, 2007 | 09:25 PM
rapidcossie
I run a zetec coilpack and have had no spark issues.
I run Rc 1000cc injectors.
The engine produces 505 bhp at the wheels, in the car on v power running 2.3 bar of boost.
Old Nov 13, 2007 | 08:24 AM
Cosworth Bassie
Default Re: atronic SM4 on ybg
I mean from the crankpully.....my mistake. And yes of course it can take reluctor or hall sensor.
AFAIK Autronic can't handle the standard sequence of the triggering from an YB, so you take off 2 teeth from the crankpully, and cut off one of the phase tooth so you get one pulse per cam shaft revolution.
Regards,
Bas
Old Nov 13, 2007 | 07:49 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
SM4 with Autronic CDI using 4 Bosch coils.
769bhp + 200shot of Nitrous with no Spark problems.
Custom loom available from MAD to drive 4 coils, with outputs to drive Launch, Anti-lag ,Flat-shift, W/I & Nitrous.
Old Nov 13, 2007 | 07:51 PM
Staffi's Avatar
Staffi
Rod, i want a passenger ride in your saff........
SOMETIME............
Old Nov 14, 2007 | 09:51 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
It can be arranged im sure .
15
Oct 7, 2015 03:43 PM
ryan_belfast
Jun 15, 2006 04:42 PM
ImaRacing 700
74
Mar 21, 2005 09:48 PM
ImaRacing 700
27
Jan 31, 2005 06:17 PM
ImaRacing 700
107
Jan 29, 2005 06:54 PM
