RS 500 RUNNING PROBLEM HAVE TRYED EVERYTHING
Old Nov 11, 2007 | 10:20 PM
carisalvage's Avatar
carisalvage
Default RS 500 RUNNING PROBLEM HAVE TRYED EVERYTHING
I HAVE JUST GOT MY RS 500 RUNNING AGAIN AFTER A REBUILD CAR TICKS OVER PERFECT BUT WHEN YOU REV IT UP IT CUTS OUT LIKE THE IGNITON HAS BEEN CUT OFF I HAVE TRYED EVERYTHING I CAN THINK OFF I HAVE REPLACE THE FOLLOWING COIL,PHASE SENSOR,CRANK SENSOR,IGNITON MODUAL WATER TEMP SENSOR AIR TEMP SENSOR, AND MAP SENSOR HAVE ALSO TRYED ANOTHER ECU ANY IDEAS WOULD BE GREATLEY RECIVED
Old Nov 11, 2007 | 10:23 PM
JonnyBravo's Avatar
JonnyBravo
Have you checked to see if the ecu is losing its ign live ?
Is the alternator charging ?
I've seen it before on other cars, not Fords though that if the ecu doesn't see 12volts then it will simply switch off.
Old Nov 11, 2007 | 10:26 PM
rsnissan's Avatar
rsnissan
have you tried the throttle sensor?
Old Nov 11, 2007 | 10:31 PM
marco polo's Avatar
marco polo
Hi Mate
i bet it's where the engine loom joins the car loom underneath the ecu
i bet the live wire is fooked
worth a try
marco
Old Nov 11, 2007 | 11:06 PM
carisalvage
I HAVE CHECKED AND IT IS CHARGING FINE
Old Nov 11, 2007 | 11:17 PM
JonnyBravo's Avatar
JonnyBravo
Check what Marco mentioned, I have heard that mentioned before
Old Nov 11, 2007 | 11:23 PM
marco polo's Avatar
marco polo
alot of the 3dr and rs500's suffer from this thats mainly the problem
it's ok ticking over but once you try to rev it , it cuts out and starts back fireing and sometimes it would just cut out for no reason thats the problem i had anyway
martin found the problem for me
persoanlly for what it's worth i would just change the whole engine loom to a pectel engine loom or a dingy or ryan loom
at the end of the day the 3drs and rs500 are 20+ yrs old electrics start fooking up after 8yrs anyway
marco
Old Nov 11, 2007 | 11:28 PM
JonnyBravo's Avatar
JonnyBravo
I was going to mention just changing the loom
Sounds like its already had enough and one thing you dont want is a part of it failing when on full chat !
Hope its fixed for now though
Old Nov 12, 2007 | 07:46 PM
AndyPen's Avatar
AndyPen
I spliced a new piece into mine when it was all out and protected it with plastic when it went back in mate. See its up for sale? Am poss in your area end of the week??
Cheers,
Andy
RB26DETT
17
May 27, 2016 11:26 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
Zoggon
Aug 10, 2015 10:39 AM
ginger1979
Jul 31, 2015 09:56 PM
