Cambelts ...
Old Nov 9, 2007 | 01:53 AM
rudeboy's Avatar
rudeboy
Default Cambelts ...
What cambelt is the best quality out there (or are they much of a muchness ), how often do folks change them and any horror stories
Old Nov 9, 2007 | 07:00 AM
I got told the gates timing belts are good. I ordered one from PJ motorsport and they supplyed me a gates belt. If your changing the timing belt you might as well change the tensioner to.
Old Nov 9, 2007 | 09:06 AM
Csm's Avatar
Csm
Yep gates belts are spot on and you must get a tensioner no questions
Old Nov 9, 2007 | 06:44 PM
Sideways_Sierra's Avatar
Sideways_Sierra
I got a Gates belt too, there was a post in general discussion some time back discussing how good Gates belts were. The end result was they were quite good.
Old Nov 9, 2007 | 09:04 PM
I used to work for toyota and they used to use gates belts as original dealer parts.
Old Nov 9, 2007 | 10:15 PM
Karl 3dr's Avatar
Karl 3dr
I always use genuine Ford ones, pretty sure they're Gate's too?
Old Nov 10, 2007 | 11:41 AM
Stu @ M Developments's Avatar
PassionFords Creator
Gates are the OE manufaturer.
Old Nov 11, 2007 | 01:30 AM
rudeboy's Avatar
rudeboy
Thanks boys
I was putting in an order with Ford ... so it looks like a new tensioner and OE cambelt is on the list
Old Nov 11, 2007 | 03:32 PM
Yeh i would mate for peach of mind.
Old Nov 11, 2007 | 03:34 PM
Old Nov 13, 2007 | 08:23 PM
westfield's Avatar
westfield
Default parts supply
hi mate,need parts for customers race car,items listed ,can you price them and e mail them, cheers chris snell cs autos,leeds,
ap 6 paddle x competition cover x thrust bearing
set of plug leads and cap x rotor x coil grp a or better,angled cap..
crank sensor
plenum gsk[cometic or similar]
cam cover[cometic or similar]
4 x spark plugs for 450hp [best ones ][denso,ford,ngk9s ??????????]
4wd water pump gsk
4wd thermostat housing gsk
grpa cambelt x tensioner,
new cam pulley bolts and washers,
ford oil filter 4wd,
need a supplier as we sort all sorts race cars, tel 01924892014,think you know our pal alastair wide ka , thanks ,hope you can sort us out,
Old Nov 14, 2007 | 08:32 AM
rudeboy's Avatar
rudeboy
Default Re: parts supply
crank sensor
4wd water pump gsk
westfield I see you need a cambelt and tensioner but what has any of this got to do with (and how does it help) my thread about cambelts
Chas
Oct 5, 2015 07:13 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
Bailes1992
Sep 3, 2015 02:17 PM
mrknifey
Aug 30, 2015 11:48 AM
Sjieter
Aug 5, 2015 09:47 PM
