makes sure the heaters go both hot and cold,not sure what its called that goes wrong with them,but wot ever it is can get jammed then the blowers will either blow out either hot or cold only
but there wicked cars mate,loads of fun to drive,great handling
Heater control valve ~£35 from Ford (bit less if you can have a mate in parts who can get trade discount ) its a piss easy job to do DIY as well, common fault with all MK4 Fiestas/Kas...
Both Fiestas ive had and the other halfs Ka have had the same problem
