Starter problem
Old Nov 7, 2007 | 04:27 PM
se mk3 cabbie's Avatar
se mk3 cabbie
Default Starter problem
I got a 97 toyota hiace (power van), some times it starts fine, other times it just clicks or turns really slow, got underneath to see if i had a loose connection etc but cant get to the f**ker, anyone got any ideas or found an easy way to access them? also how hard is it to do a cambelt change on these, diesel by the way, thanks
Old Nov 7, 2007 | 04:38 PM
lardypants's Avatar
lardypants
sounds like a possible earth fault mate remove the earth from engine to chassis clean and re attatch, i had similar recent on a galaxy tdi in the end i moved the earth so it mounted in the starter bolt hole
Old Nov 7, 2007 | 04:51 PM
se mk3 cabbie
cheers mate i will try that tomorrow
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
