Anyone use KnockLite for knock monitoring?
For example TurboXS or any other?
It connects to factory knock sensor or into separate knock sensor (sold separately) and flash to alert you to the knock...
So, its a shit or realy device which can alert the knock in cossie engine?
Or may be you have some other method to knock monitoring...
Thank you!
Thank you!
For during normal use to notify you of an abnormal condition, im confident it would be useful, although doubt it would be a "perfect" solution due to the inherent inaccuracy of it.
For mapping though, forget it.
What do you want it for?
