zetec in a sierra...wont start?????
Old Nov 3, 2007 | 07:23 PM
3drzetec's Avatar
3drzetec
Default zetec in a sierra...wont start?????
hello, i need your help. engine run lovly in the mondy, fitted new cambelt, timings right. its on 40's. alpha/weber ecu.sparking but wont start. popping out exhaust. any ideas. any body now where to take it to get set up, n.wales area. its a 2.0lt silver top thanks
Old Nov 4, 2007 | 05:17 PM
Wardy257's Avatar
Wardy257
Are you using the map that came with the ECU?
The problem with webber alpha is only their dealers can touch the ECU which wont help you. Have you tried spraying easystart down the carbs as you crank? Did webber supply the car jet sizes or have you guessed?
Old Nov 4, 2007 | 09:42 PM
Do you know if your getting fuel to the engine.
Old Nov 6, 2007 | 09:15 PM
16vzetec's Avatar
16vzetec
sounds like timing out or the spark out of time.
Old Nov 23, 2007 | 07:54 AM
mappindude's Avatar
mappindude
You got the plug leads on right?
JoeyBoyden
Jan 4, 2024 02:36 PM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
robnock
Aug 22, 2015 10:51 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
