problem injectors help plz
Old Nov 3, 2007 | 11:20 AM
k10cos's Avatar
k10cos
Default problem injectors help plz
hi people i have a cossie and the 4th injector is not spitting as it should is it more likely to be the wiring connection or the injector i can see a bit of bare wire near the connector
cheeRs
Old Nov 3, 2007 | 12:12 PM
jon@work's Avatar
jon@work
swap the injector to a different cylinder and see if its performance improves
repair the wiring if it looks damaged - whether it is at fault or not
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
cos elle
Sep 16, 2015 06:37 PM
tib2220
Sep 14, 2015 12:33 PM
markk
Sep 9, 2015 08:11 AM
