oil pump priming
Old Nov 1, 2007 | 09:03 PM
PAZ's Avatar
PAZ
Default oil pump priming
hi all do i need to prim my oil pump on my 3 door coz as i have had to take my sump off due to a stripped drain plug hole.the sump has been off for 6 days now and oil has been dripping out off the pick up pipe.i have not touched the oil pump at all,and the oil filter is still on many thanks paz
Old Nov 1, 2007 | 10:36 PM
Rabbit's Avatar
Rabbit
yes you should prime it...you dont want any air bubbles in the oil supply!
Old Nov 4, 2007 | 09:45 AM
stage 3 muppet's Avatar
stage 3 muppet
i always prime mine buy machine oiling pump internals then apply some vaseline always worked fine for me mate and yes vaseline works a treat
if engine out then backfill pick up pipe with light oil and then block end with a touch of vaseline
little trick an old skool engine builder up the road from me showed me
always worked fine for me before anyone slates me
did this two mths aga after rebuilding my yb lump
Old Nov 5, 2007 | 01:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
easy way to do it - remove the distributor and put a 1/4" drive socket onto the hexagonal drive shaft and spin it up using a cordless drill
Old Nov 5, 2007 | 03:31 PM
cossiegreg1's Avatar
cossiegreg1
cool tip.
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
