Missfire?
Old Oct 31, 2007 | 05:09 PM
Paul_RS's Avatar
Paul_RS
Default Missfire?
Ok, changed, plugs, cap, arm and i still occasionally get a strange missfire around 5000ish rpm.
Sometimes it sounds like mild antilag and won't go through the miss. Loads of smoke out the exhaust too. Other times it just hesitates and goes through it and sometimes it doesn't do it at all
Could it be the phase sensor? i think its an ignition and the smoke is unburnt fuel....
Old Oct 31, 2007 | 08:37 PM
charlie luciano's Avatar
charlie luciano
which cossie variant do you have Paul?
Luciano
Old Oct 31, 2007 | 09:05 PM
saff cosworth's Avatar
saff cosworth
check your plug leads...
Old Oct 31, 2007 | 10:23 PM
Gordon1's Avatar
Gordon1
what boost are you running and what coil do you have
Old Oct 31, 2007 | 11:51 PM
Paul_RS's Avatar
Paul_RS
Sorry, more details as requested!
Its a 1991 4x4
Ignition -
New group a coil
New ididium NGK plugs (also have a set of NGK 9's)
New cap
New arm
Leads are not new, but look in good condition and are genuine beru items
Its running 8 dark greens on a pectal super 8 ecu
genuine 500 cooler, hoses, inlet and throttle body. Set to hold 28PSI on high boost (has a 12 pot boost controller)
Engine loom has been replaced in the last few years as well going by the reciepts....
I was thinking about leads, but i didn't want to waste Ł80 on them only for the miss to remain.
Old Oct 31, 2007 | 11:55 PM
charlie luciano
When you get the mis-fire is the rev counter going skyward/jumping around?
Luciano
Old Oct 31, 2007 | 11:57 PM
Paul_RS's Avatar
Paul_RS
Yup it goes nuts, flys way past 7000!
I've been told the wee box thingy that attaches to one side of the coil can cause this? I left it in circuit when i change to the group a.
Old Nov 1, 2007 | 12:06 AM
charlie luciano
Not too sure on the box thingy you mention but usually if the rev counter is jumping around it means you have got engine loom problems my car started to do this and at first I cut the loom plugs out of the loom and soldered the wires together, these plugs run along the back of the rocker cover/bulk head, this lasted for about sixteen months and then the same problem came back, under boost the car would mis-fire and the rev counter would jump around/go skyward, replaced the engine loom in whole and now car runs as it should with no pesky mis-fire
Luciano
Old Nov 1, 2007 | 12:20 AM
Paul_RS's Avatar
Paul_RS
As far as i can tell the entire loom was replaced at most 5 years ago and the car has only done a few thousand miles and lived in a carcoon since (well until i got it )
But i'll investigate the loom further mate, it may even be as simple as crap in the connecting plugs!
Thanks for the pointer chum - i owe you a pint
Old Nov 1, 2007 | 12:26 AM
charlie luciano
I'll hold you to that Paul nice 1 mines a guinness
always good to help out others and pass on advice and experiences its annoying when these cars don't run right
Luciano
Old Nov 1, 2007 | 12:43 AM
Paul_RS's Avatar
Paul_RS
Dublin it is then, for the best Guinness
I appreciate the pointers - saves me so much time messing around trying to work out whats going on!
Old Nov 1, 2007 | 10:55 AM
silky16v's Avatar
silky16v
Get on That!
sound the same problems are was having with mine very similar setup also with a L8 with pectal super8 board and RS500 inlet, etc
I bought new 909 leads, cap, arm & 017C plugs, replaced the Ignition Amp also with a brand new item and cleaned off the old silicone compound off the aluminium backing plate and applied new compound this totally solved the problem.
Before hand sometimes it would drive threw it, but it got worse at night, the misfire doesn't do ya engine any favours either so be careful
I also fitted new earth from side of the head to battery and checked , cleaned & replaced all connection on the alternator, by doing this i picked up over 0.65v at the battery when light where on and engine ticking over.
I for 1 would replace the leads cause they make look ok but they could well be arching out under load.
also without fail check all sensor gaps & condition as well as loom condition and voltage at ECU
Old Nov 1, 2007 | 06:03 PM
saff cosworth
" rev counter jumping "
this happened to me too, turned out to be the leads under load.
even threw the ecu off a bit leaving one of the injectors open.
get a loan of a set of leads and see if this works first...
regards paddy...
Old Nov 1, 2007 | 10:33 PM
Paul_RS's Avatar
Paul_RS
I used contact cleaner on the engine loom plugs and the problem seems to be solved
@silky and saff - I think i'll buy a new set of leads as a matter of course, that way i know they are 100%
Is there a massive difference between the 909 leads and the beru originals?
Old Nov 1, 2007 | 10:41 PM
silky16v's Avatar
silky16v
Get on That!
can't answer that the 909 leads are thicker though and new leads can't do any harm i reckon
Old Nov 1, 2007 | 10:43 PM
Paul_RS's Avatar
Paul_RS
Cheers mate
More money down the drain on the aul sierra
Old Nov 2, 2007 | 08:36 AM
silky16v's Avatar
silky16v
Get on That!
Cheers mate
it a cossie what do you expect
Old Nov 2, 2007 | 06:17 PM
saff cosworth
she can be a pain,,, but you love her anyway...
Old Nov 2, 2007 | 07:20 PM
BIL N KEL's Avatar
BIL N KEL
thats what was wrong with my mates car when it was happening to his
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
Ginge !
23
May 28, 2005 01:06 PM
FletchCossie
Jul 19, 2004 08:17 PM
AlexD
Feb 26, 2004 08:59 AM
