cossie cutting out
Old Oct 30, 2007 | 09:05 AM
russell's Avatar
russell
Default cossie cutting out
Hi, could do with a little help! i have a 4x4 cossie and had the head gasket done at the weekend and all seems to run ok till i give it some stick, i get two really big bangs and then just cuts out. But does start after and runs fine again. Any ideas?
Old Oct 30, 2007 | 05:36 PM
ladsarmy's Avatar
ladsarmy
Default car
have you checked the plugs or the map sensor
Old Oct 30, 2007 | 06:01 PM
russell's Avatar
russell
yes all plugs seem ok, could it be something to do with the phase sensor?
ill check the map sensor though thanks.
Old Oct 31, 2007 | 10:23 AM
ladsarmy's Avatar
ladsarmy
Default reply
when mines donr this there was a split in the map sensor hose
Old Nov 23, 2007 | 08:03 AM
mappindude's Avatar
mappindude
Sounds like it my be overboosting
you got the pipes on the amal valve the right way round?.
or is the pipe to the actuator split?
Old Nov 23, 2007 | 06:17 PM
COLEYST200's Avatar
COLEYST200
right have a go at this my mate had the same as you have on a escort 4x4 cosworth and it was one of the wires going to the dizey it had brock right at the plug it was not till he spock to RYAN and he told my mate the pin outs and one of them was dead . his car ran with the plug off so have a good look i think you will find its the same problem
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
