ignition retard on boost on n/a breakerless ignition ???????
Old Oct 27, 2007 | 06:37 PM
scoooby slayer's Avatar
scoooby slayer
Default ignition retard on boost on n/a breakerless ignition ???????
is it possible to use original management on a n/a car thats been turboed with breakerless ignition. i know old school distributors could be retarded manually but is there any way on a fixed breakerless system ?
Old Oct 27, 2007 | 06:39 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Turbocharged cars generally have a rising rate fuel pressure regulator - the higher the boost pressure the higher the fuel pressure upto a set maximum
Ginge !'s Avatar
Ginge !
just finding my feet
Old Oct 27, 2007 | 06:49 PM
scoooby slayer
so if i get an adjustable rising rate fpr and some 635 injectors that should sort fueling then
anyone know an easy way to retard ignition on breakerless ignition ? from what ive read need retarded ignition for when on boost
Old Oct 27, 2007 | 07:07 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Some dizzy's have a diaphram in them to allow retard on boost.
I dont know off had on that will direct fit an E30
Failing that, you can get a delay box to retard it for you, it just takes the pulse and waits a while before passing it on essentially.
Old Oct 27, 2007 | 07:14 PM
scoooby slayer
it i used an early distributor with the vacuum advance on the side would it work opposite when it sees boost and retard it
Old Oct 27, 2007 | 07:59 PM
davidreader5's Avatar
davidreader5
As chip, dont know if still available but years ago turbo technics had a diaphragm type vacuum two way advance unit that advanced under vacuum and retarded the ignition when on boost, when i did a escort cvh in 93, for some reason had to use a bosch type dizzy and the advance linkcage rod had to be cut to give the required amount of ignition retard. i think the old audi's and saab had this advance unit. i was on the limit of det @ 12psi.
Regards Dave R.
Old Oct 27, 2007 | 08:06 PM
Fiecos Dan's Avatar
Fiecos Dan
The dissy boost retard capsule is off early turbo Saab's. i convert them to fit other dissy's, abit like TT used to.
But you can run a Micro Dynamic's EMs 5 or 6, to retard once boosting, and the 5 is adjustable to how much retard, @ what rpm, and also allows for the timing to be re advances after the det threshold has passed.
Old Oct 27, 2007 | 08:58 PM
mk1 chris's Avatar
mk1 chris
MSD do a boost timing control unit, it automatically retards a preset amount of timing per pound of boost IIRC.
it was called a boost timing master
Old Oct 27, 2007 | 09:36 PM
Mark V8's Avatar
Mark V8
Mark
Old Oct 27, 2007 | 11:03 PM
scoooby slayer
cheers mate checked them out have to be run with msd management. they do a stand alone controler but its for points systems only
il keep searching the net though i know what im looking for now
Old Oct 28, 2007 | 10:15 AM
Fiecos Dan's Avatar
Fiecos Dan
Here's the one i have on my TT now. fitted with late xr2 dissy setup, and grpA coil.
http://modifying.demon-tweeks.co.uk/...EMS5&grp=RC014
and here's the cheaper version.
http://modifying.demon-tweeks.co.uk/...EMS6&grp=RP111
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
