P0460 Fuel Level Sensor Circuit Malfunction
Old Oct 27, 2007 | 09:04 AM
pani_k's Avatar
pani_k
PassionFORD Member
Default P0460 Fuel Level Sensor Circuit Malfunction
Hey all,
EML light came on last night and just found this code on my car along with another one but I believe that one to be because of the de-cat. I found this via the bluefin I have. Should I be worried about this and what does this normally mean the problem is?
The car drives fine in every way and I cleared the code with the bluefin and the code has not come back yet. Ford Focus MP3 1.8 Zetec
Old Oct 27, 2007 | 09:08 AM
RichieST's Avatar
RichieST
quite common for the fuel level sender to piss about on the focus, you may see the gauge go up and down of its own accord, mine used to do it a lot!!
Never heard of it making the management light come on tho!
Old Oct 27, 2007 | 09:11 AM
pani_k's Avatar
pani_k
PassionFORD Member
there was another code which was O2 sensor slow response P0133 but I have a decat exahust system which is where that probably came from. But EML light came on (I shat myself when it did ) drove home safely, bluefinned it this morning and all is well (so far)
Old Oct 27, 2007 | 10:14 AM
DENNIS's Avatar
DENNIS
what O2 sensor was it sensor 1 or sensor 2 ?
if its sensor 2 ( post cat ) then you are correct, its because the cats been removed, although there are kits to trick the ECU to give a false signal back to the ECU so it assumes the CAT is working fine.
if its sensor 1 then there maybe a problem.
as for the fuel gauge code, the engine ECU will use the fuel level sensor as part of the misfire detection processes, if its not a present code and the gauge works fine, clear it and see if it returns. this will have no effect on the way the car drives as its purely for a diagnostic aid for the ECU.
Old Oct 27, 2007 | 12:16 PM
James's Avatar
James
nearly all older shape focuses have that code present-fuel gauge one.
Old Dec 17, 2010 | 11:16 AM
jsulen's Avatar
jsulen
Hi I am just new here in this forum and I would like to ask if you know an online site where in I can buy b.new hella fuel level sensor? Thanks in advance.
jessie_rs
62
Aug 6, 2019 09:27 PM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
