Wont Start
Old Oct 26, 2007 | 11:19 AM
RS16iDale's Avatar
RS16iDale
Default Wont Start
rite my track car has been puzzling me for a while now cuz i cant get it running.ive tryed everything i can think of but still no luck hopefully u guys can help.
2ltr zetec with xr2i 16valve loom,and desk ecu from a scraped mondeo.it is sparking but has no fuel coming up even with a wire straight from the pump to the battery you can hear the pump workin and there is fuel in the new fuel filter. i connected up another injector rail ontop of the rocker cover but still no fuel squirting out of the injectors.
i took off the injector loom to inspect for damage and found that some of the wires had chaffed so tested each wire for continuity and they was all fine so tapped them all up so nothing touching but still no fuel.
i had the idle speed control valve and injector 1 plug mixed up so number 1 injector was getin 12v wen the ignition was on could this have damaged the ecu?? or could i have the fuel pipes around the wrong wasy as it was a cvh lump before a zetec??
please help cheers dale
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
