speedo cable
Old Oct 25, 2007 | 11:16 AM
muffster's Avatar
muffster
Default speedo cable
Cheers fellas, it came out just as described
It hasnt solved the problem though! I drove the car with the clocks out so i could see the cable and the core inside turning when the car was moving and it spins around freely. Any ideas why the speedo needle is bouncing around all over the place? The car has been in a garage for some time but was fine before that.
Many thanks.
Muffster.
Old Oct 25, 2007 | 11:47 AM
antony215's Avatar
antony215
Escort Rs Turbo
Is the cable in the gearbox end properly? when you connect it to the clocks it needs to click in if it dont then its not in properly
Old Oct 25, 2007 | 05:29 PM
muffster's Avatar
muffster
Hi mate.
Yes i checked the gearbox end first. I removed the circlip to have a look at the cable to see if it was intact. It seemed ok so i tried the other end at the clocks. After re-fastening both ends the speedo needle still has a mind of its own!!!???????
Cheers.
Muffster.
Old Oct 25, 2007 | 05:40 PM
antony215's Avatar
antony215
Escort Rs Turbo
Might be the clocks them self gone then mate can you try another set??
Old Oct 25, 2007 | 09:57 PM
lukemakepeace's Avatar
lukemakepeace
it sounds to be the springs insode of the clock mechanism. they generally keep it stable and return the needle to 0. if these go or stretch they dont work properly and cause the needle to go everywhere!
sounds like either new clocks for you or you can change over the back parts. but new clocks are much easier.
muz
Sep 30, 2015 08:29 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
