RS Turbo idle?
Old Oct 25, 2007 | 10:32 AM
benreader's Avatar
benreader
Default RS Turbo idle?
1989 ERS2. only happened yesterday, started to idle at just under 2000rpm. anyone know how or why this would happen and how i can turn the idle speed down if possible?
cheers!
Old Oct 25, 2007 | 10:33 AM
ballin's Avatar
ballin
probably an airleak mate
Old Oct 25, 2007 | 10:45 AM
benreader's Avatar
benreader
where do i want to be looking to check for this, i take it that the idle will get worse? why does it affect the idle?
Old Oct 25, 2007 | 10:59 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
common for the breather vac pipe to come apart on the inlet manifold
Old Oct 25, 2007 | 11:54 AM
twinkle_2k86's Avatar
twinkle_2k86
Any air leak on a MFi rs turbo will make the engine die. Possible the ISCV as said above.
Old Oct 25, 2007 | 12:02 PM
davidreader5's Avatar
davidreader5
HI is this with the engine warmed up to operating temp, if so check the auxiliary air device, does similar job as cars with iscv,(idle speed control valve) the valve should be open witht the engine cold, if you dont know what it is or how to check it, get someone who does should be about 10,mins work to check but longer to change the valve.
Regards Dave R.
Old Oct 25, 2007 | 12:39 PM
benreader's Avatar
benreader
no it just goes straight to 2000rpm, only started yesterday like i said. where is the iscv located on my car?
Old Oct 25, 2007 | 02:25 PM
davidreader5
The auxiliary air valve is under @ the back of the inlet manifold, it has 2,plastic pipes conected to it one in and one out , here is a scan picture.
The info is for s1, but similar pins on s2 relay, you can for now try turning the idle speed down by using the idle screw by the throttle switch.
if you need a auxiliary air device valve i have plenty.
Regards DAVE R
Old Oct 26, 2007 | 09:54 AM
benreader's Avatar
benreader
right this morning i had a look in a bit more detail what actually happens. when i fire the car up the engine sets itself at 1100rpm as it should, it then gradually rises over about a minute to 1900rpm but then stays there. if i start the car and rev the engine as i fire it up the revs then reset to 1900rpm almost straight away. its like once i rev past 1900rpm the idle then settles at this??
Old Oct 26, 2007 | 03:34 PM
benreader's Avatar
benreader
anybody??
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
