Car Will Not Start?...
Old Oct 24, 2007 | 10:42 AM
Daniel1431's Avatar
Daniel1431
Default Car Will Not Start?...
Hello
I have a Fiesta Zetec 1.25 W Reg.
Came to start the car today and put the key into the ignition and turned the key and the car just makes a fast ticking sound and will not start. I used it last week so the battery shouldn't be flat but when i lock the car the motors which lock the door sound like they have hardly got any power.
Do you think it could be a flat battery or Starter Motor?
Old Oct 24, 2007 | 01:07 PM
antony215's Avatar
antony215
Escort Rs Turbo
Sounds like your batterys dead mate
Old Oct 24, 2007 | 02:39 PM
lukemakepeace's Avatar
lukemakepeace
battery.
Old Oct 24, 2007 | 05:08 PM
talksr's Avatar
talksr
Yep sounds like the battery. My focus did this, and I thought that water had got in the fuse box or something because of the electrical ticking, a quick call to my local ford garage confirmed it was the batt.
Even though the lights, wipers and radio all still worked, they said, if the battery goes under a certain level, the car will not start up.
Sounds just like the problem I had. I don't know if the fiestas will do it but on the focuses or foci when you start the ignition the RMP and odometer needles will go up to their maximum and then back down. I would expect that it may not happen on yours as I don't think fiesta instrument clusters are quite as digitalised as the focuses.
Old Oct 24, 2007 | 05:17 PM
Yeh i would say battery to. If you can get hold of a multimeter you could check it with that. The multimeter will tell you how much voltage is in the battery.
Old Oct 24, 2007 | 05:56 PM
lukemakepeace
get yourself a decent one. calcuim ones are quite good i got a calcuim one not long ago as my car started dying and this one great.
MY OTHER BATTERY WAS 10 YEARS OLD!!!!!!!!!! had been in there since car was made.
but i got me a good one and its nice!
Old Oct 30, 2007 | 09:31 AM
Daniel1431's Avatar
Daniel1431
Thanks for the replies guys! It turned out it was the battery as i charged it and now it is fine....
However i drove the car last night only to find that the Heated Rear Window and Main Blowers are not working. The blowers work but do not blow out warm air. The temprature gauge is possitioned in the middle which shows that it is fine. I will check the fuse board when i have finished university later on today as i think it could be a fuse.
Old Oct 30, 2007 | 09:44 AM
talksr's Avatar
talksr
Glad to hear it was the battery and its all sorted.
My first suspicion with the heaters would be the fuse too. I hope that is what it is.
Good luck!
Old Oct 30, 2007 | 11:32 PM
Daniel1431's Avatar
Daniel1431
Turns out it was not the fuse so i have no idea what it is
mk22door
49
Mar 26, 2022 07:15 AM
Adam-M
22
Aug 10, 2015 10:46 AM
xr_craig
Aug 7, 2015 06:00 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
ginger1979
Jul 31, 2015 09:56 PM
