Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Puma Rally car
Old Oct 16, 2007 | 03:47 PM
Trisrallypuma's Avatar
Trisrallypuma
Default Puma Rally car
I have been offered a very cheap puma 1.7 that i want to make into a rally car, does anyone know anyone who has done this?
Does anyone have any information on places to source puma rally parts?
Will any 2l 16v engines drop onto the same mounts as the 1.7 as i need about 200bhp to be competative......
Thanks in advance!
Tris.
Old Nov 16, 2007 | 09:23 PM
Featherz's Avatar
Featherz
There is no such thing as a cheap rally car... you would need a roll cage welded in which isnt cheap to buy or fit really, fire extinguisher, decent suspension, decent rally tyres, and then engine wise nothing bolts straight in would all be expensive.
Best bet would be trying to get the standard 1.7 engine upto FRP spec, and maybe later on think about throttle bodies
I know were on a ford forum here but get a pug 205 gti great base for rallying,.. parts are cheap, there light and best handling hatch really ever.... you can pick up a 1.6 or a 1.9 for around 1.5k for a good un and cheaper if your great with a spanner...
Old Nov 16, 2007 | 09:39 PM
Dal_'s Avatar
Dal_
ALL the puma rally cars were 1.6 not 1.7, and for good reason.
The 1.7 uses nikasil linings in the piston bore, where as the 1.6 uses far stronger and durable steel ones. Whilst the 1.7 is a very revvy engine and good for road use, it can't handle the constant loads and stress that the steel lined 1.6 can : especially when rallyed.
Most people that do a turbo's puma, will use a 1.6 as it's not as frail as the 1.7
Old Nov 19, 2007 | 03:49 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
all the puma rally cars were 1600cc because thats the class they were in!!!
you cannot run a 1700 in super 1600 class now can you!!
Old Nov 19, 2007 | 05:06 PM
OldDan's Avatar
OldDan
And the engine was a 1700 changed down to a 1600!
OldDan's Avatar
OldDan
They also did some 1.4 puma rally cars IIRC?
Old Nov 19, 2007 | 05:30 PM
Micky The Finn
Former Sponsor
yep,1400's also.
Old Nov 19, 2007 | 05:32 PM
OldDan's Avatar
OldDan
Sweet
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
matman
Sep 9, 2015 05:45 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
Ben26
Aug 11, 2015 04:19 PM
Aug 10, 2015 12:08 PM
