programming new keys 95 escort cos
Old Oct 13, 2007 | 11:31 PM
Rashers's Avatar
Rashers
Default programming new keys 95 escort cos
Got a new lock set changed the ignitiion barrel now how do i programme my new keys so i can start the bastard ...................any help appreciated or is this a main dealer job
Rashers
Old Oct 14, 2007 | 08:15 AM
Do you have a red master key ?
Old Oct 14, 2007 | 07:20 PM
Rashers's Avatar
Rashers
yes mate got a red master
Old Oct 14, 2007 | 07:42 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
turn ign switch to 1 four times within 8 seconds
clock led iluminates for 5 seconds
remove master key while iluminated
insert key to be programmed
turn to position 1
led goes out for 2 secs then iluminates again
repeat within 30 seconds to any other keys to be programmed
to exit programming mode turn to position 2 and wait for 30 seconds
if this dosent work it says there is another way to try too let me know
tommy
Old Oct 15, 2007 | 05:12 AM
The above should work, just hold the master key, next to the cowling, or better still take cowling off, as if I understand it you will not be able to insert it and turn as wrong key now with lock change.
Red masters can be reset at dealers if this does not work, I had one red key supplied and programmed, + two black keys, all in about Ł60 from memory.
Old Oct 15, 2007 | 07:45 AM
Aaroncast's Avatar
Aaroncast
>>>>>>>>instuctions in your handbook also!!------
HIDE/TUCK AWAY THE RED KEY WHEN DONE WITH.
Vincereese
Jun 1, 2023 09:14 AM
Carlbacciochi
24
Jun 30, 2016 04:31 PM
FlashRS
Sep 14, 2015 12:36 PM
Bighandsuk
Sep 2, 2015 05:23 PM
Vincereese
Aug 18, 2015 03:57 PM
