2wd cossie 4 pots
Old Oct 13, 2007 | 08:49 PM
<____ALEX____>'s Avatar
<____ALEX____>
Default 2wd cossie 4 pots
dose anyone know if it is possible to fit the 2wd cossie 4 pots and standard cossie disks to a s2 escort rs? iv heard the will fit straight on with longer bolts and aew washers?? has anyone done this befor? thanks
Old Oct 13, 2007 | 10:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
The 2wd 4 pots need some machining done (about 4mm) to the caliper the 4wd calipers are the one that just need washers and bolts to fit.
Old Oct 14, 2007 | 01:46 PM
<____ALEX____>
hmmm i see . are the 4 pot lot better than the 4x4 calipers?
Old Oct 14, 2007 | 02:12 PM
4wd brakes are shite 2wd are ace.
4wd belong on a bicycle 2wd on a car.
4wd cossie brakes no better than any other single piston type of the same size, ie mondeo etc.
Old Oct 14, 2007 | 03:21 PM
antony215's Avatar
antony215
Escort Rs Turbo
As tabetha says there not really worth the work if you want a quick cheap upgrade then just get the brakets and fit 2wd disks and keep your s2 calipers they will work just as good as the 4wd calipers.
Old Oct 14, 2007 | 03:36 PM
tont2002's Avatar
tont2002
theres a good how to guide on www.rsbible.co.uk
Old Oct 15, 2007 | 10:17 AM
<____ALEX____>
thanks people
Old Oct 15, 2007 | 11:56 AM
<____ALEX____>
can you tell me where i can find some brakets to mount the 2wd calipers??
Old Oct 15, 2007 | 12:08 PM
<____ALEX____>
actually,do i even need brakets??? i just been reading the rs bible and it dose not say anything about brakets he just mentions about machineing the face of the calliper 4mm to fit the standard cossie disc? whats that about?? i cant go any bigger than standard cossie disk size as im still using 15" rs wheels.
Old Oct 15, 2007 | 12:21 PM
If you are using rst brackets/brakes then you will need bracket to space out, if using 4wd cos then you don't need brackets.
Old Oct 16, 2007 | 05:52 AM
derekg7156's Avatar
derekg7156
The 4 pots need 4mm machined of the face the hubs redrilles and tapped to m12, aslo the will not fit under the standard wheels without spacers they foul on the back of the spokes.
Del
Old Oct 16, 2007 | 08:09 AM
<____ALEX____>
hmmm well i think for now i may just do what antony215 said and use my calipers and the bigger disks.dose anyone know where i can get hold of some mounting brackets for this???
Old Oct 16, 2007 | 11:27 AM
SafeChav's Avatar
SafeChav
You don't need brackets no.
You have to have the caliper machined as said, then you have to tap the hubs out to an M12 thread and get some high tensile cap head bolts to fasten them.
The biggest problem with this upgrade is the brake pipe connections, as when fitted they point out directly at the CV joints so you can't use normal brake pipes.
Old Oct 16, 2007 | 01:01 PM
antony215's Avatar
antony215
Escort Rs Turbo
This is what you want if your keeping your s2 calipers and fitting cosworth 2wd discs
http://www.randbmotorsport.co.uk/sho...p?ProductID=49
Old Oct 17, 2007 | 02:44 PM
stuartrsturbo's Avatar
stuartrsturbo
If you buy this months Fast Ford they have done a step by step on how to fit cosworth caliper to an Escort.
Old Oct 18, 2007 | 09:47 AM
<____ALEX____>
thanks guys,gunna give it a go,do ya recon they will make alot of difference?
Old Oct 18, 2007 | 02:03 PM
SafeChav's Avatar
SafeChav
4 pots should make a very noticeable difference
Old Oct 19, 2007 | 12:27 PM
<____ALEX____>
good good. at the moment im running black diamond drilled/groved disks and ebc greens and they still fade loads.replaced all the fluids and still dose it? so i think it shal have to be bigger disks.
Old Oct 19, 2007 | 09:56 PM
SafeChav's Avatar
SafeChav
Try using BETTER fluid, if your getting fade changing the calipers isnt going to solve that!
Thats more than likely the fluid boiling.
Old Oct 20, 2007 | 08:13 AM
<____ALEX____>
rite,just bought this months fast ford and its telling me all about this conversion,it all looks good but it says you need a rs2000 handbrake cable,so i looked for one and it turns out there are like 3 different sizes? ? dose anyone have an idea which length i should use???
2987mm
1470mm
1415mm
anyway thanks for the help people
Old Oct 20, 2007 | 09:34 AM
antony215's Avatar
antony215
Escort Rs Turbo
2987mm
1470mm
1415mm
Thought you were doing the front not the back???????
Old Oct 20, 2007 | 09:44 AM
&lt;____ALEX____&gt;'s Avatar
i am doing the front. just thinking on what i will need to do the back aswell.
Old Oct 20, 2007 | 09:57 AM
antony215's Avatar
antony215
Escort Rs Turbo
Id leave the standard drums on mate there just as good having discs on the back can cause all sorts of problems
Old Oct 20, 2007 | 10:27 AM
yer i herd that it can cause trouble mate,if i were to change them it would only be for looks to be honest so dont really need em
Old Oct 20, 2007 | 01:34 PM
SafeChav's Avatar
SafeChav
discs are easier to work on than the drums but the conversion can be a bit of a headache, if you're going to do it get brackets that mount the calipers at 12 o'clock that will make it considerably easier all round.
Old Oct 20, 2007 | 01:38 PM
yer iv got the dimensions for brakets that sit a 12o clock possition, dosent that have summin to do with when you bleed them? how thick do you recon the brackets should be? iv got the dimensions for everything else just not the thickness, bout 150mm????
Old Oct 22, 2007 | 10:41 AM
SafeChav's Avatar
SafeChav
It makes them easier to bleed and also stops the handbrake cable being a tight stretch.
150mm???? If/when you strip the drums off refit the bearing housing and measure the distance between that and and the hub, and then subtract off say 1mm for clearance, and that will be about as thick as you can have them really.
Old Oct 29, 2008 | 07:27 PM
mikemcc03's Avatar
mikemcc03
hi could u tell me which issue the caliper conversion in fast ford was in plz?
Old Oct 29, 2008 | 07:37 PM
coswurv's Avatar
coswurv
issue 259, november 2007
Old Oct 30, 2008 | 09:11 AM
mikemcc03's Avatar
mikemcc03
cheeRS coswurv!
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
focus2351
Sep 9, 2015 09:33 PM
