Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
is this normal?
Old Oct 7, 2007 | 10:53 PM
scottg17's Avatar
scottg17
Default is this normal?
Hi... just bought an escort 1.6 p reg 57k on the clock....
After having a frency car i will say never again.... always stick with the oval!.. had a saxo 1.1 and the head gasket blew.... then it had an idele problem.... then the faul pump went.... and then the head gasket went again!!! pure rubbish!
Was driving it tonight.... in town the temp gague was between the r and the m in 'NORMAL' but when i took it out on the open road... the temp gague dipped into the white section and sometimes off the scale...
is this normal??
Thanks!!!!
Old Oct 8, 2007 | 05:48 AM
The engine sounds ok temp wise, just the gauges do act a bit quick, yours sounds like it may need a new temp sender, my dads mondy runs around the A a lot in traffic, but goes down to O when along open road.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mile30
69
May 13, 2017 08:44 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
