zetec engine spluttering!
Old Oct 5, 2007 | 06:43 PM
pratley's Avatar
pratley
Default zetec engine spluttering!
Just finished fitting my new 2.0 zetec into my fiesta and started it up for the first time tonight. It started fine but keeps cutting out and spluttering at low revs. Took it up the road and seems to drive ok, but as soon as you let off the revs it cuts out
Could it be the petrol thats been sat in my tank for bout 3 months or probably something else? It has the rs1800 ECU in it, would this cause it to run badly as its now a 2.0?
Any help would be much appreciated
Old Oct 6, 2007 | 06:06 AM
Wardy257's Avatar
Wardy257
Did you fit the VSS? Running on the wrong ECU wont help to.
Old Oct 6, 2007 | 06:30 AM
It won't be the petrol.
ECU will cope fine with the increrase in cc as it does not even know and will have enough built in adaptability for this.
Old Oct 6, 2007 | 07:49 AM
pratley's Avatar
pratley
Default vss
Sorry but what is VSS
Thanx
Old Oct 6, 2007 | 09:32 AM
Wardy257's Avatar
Wardy257
Vehicle Speed Sensor.
Tabetha, the ECU's adaptive stradegy is clever, but not that clever.
JoeyBoyden
Jan 4, 2024 02:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
