rs turbo cab HELP............
Old Oct 3, 2007 | 06:29 PM
rs gez's Avatar
rs gez
Default rs turbo cab HELP............
Been offereda escort rs turbo cab but been told piston has cracked???
is this a big job and if so how much should i be paying for rebuild??
want to take this as a project or get it fixed at garage not sure yet though???
please help before i buy it off my mate and end up with a real headache or possibly bargain???
Old Oct 3, 2007 | 06:35 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Cracked piston is fairly serious. Replacement engine or proper rebuild really.
Old Oct 3, 2007 | 06:37 PM
rs gez's Avatar
rs gez
so thats dear then?? been offered car cheap ish??
just thought it surely cant be too hard to rebuild one or expensive??
its a ford lol!!!
Old Oct 3, 2007 | 06:39 PM
Christian and Beccy
#1 in Spelling Club
Depends on how you want it to turn out. Best bet to fix it cheaply is a second-hand engine, but its a gamble.
If the piston really is cracked, it's likely to have scored the bore and potentially ruined the block.
How does he know the piston is cracked?
Old Oct 3, 2007 | 06:42 PM
rs gez's Avatar
rs gez
he is guessing it has cracked as he has been told of one of his mates it is????
symptons are oil in intercooler pipe and major back pressure thru oil filler cap and dipstick???plus loadfs of blue smoke!!!
Old Oct 4, 2007 | 11:30 AM
rs gez's Avatar
rs gez
any other ideas guys???
Old Oct 4, 2007 | 11:32 AM
DanCossie's Avatar
DanCossie
Post Whore
chris has told you what to do mate...and given you most scenarios mate.
how much is it and depends how much you want from the engine will determine how much it will cost to put right etc...need a bit more info to be honest mate
Old Oct 4, 2007 | 11:36 AM
scoooby slayer's Avatar
scoooby slayer
had a cat engine do this had a hole in piston was in the middle though didnt hurt the bore. if its cheap enough then worth the gamble id say. may only be one piston, hone and re ring and new bearings and headgasket and away.
Old Oct 4, 2007 | 11:37 AM
rs gez's Avatar
rs gez
i dont know much though dave just at what he has told me and what isee ie smoke comeing from rocker cap and dipstick and loads of oil in intercooler pipes just want a rough idea on how much to rebuild it myself or with a little help ie i strip everything down get all the parts then get some one who knows what they are doing to help me rebuild it???
tbh getting another engine could be a big mistake i think as it may only be slightly better than the engine thats in it now barr the smoke???
Old Oct 4, 2007 | 11:48 AM
gingeRS's Avatar
gingeRS
tell us how much the car is (dont worry no-one will buy it out from under your nose)
what the spec is, bodywork etc, then we can make a decision as to whther its worth it.
an engine rebuild on a CVH can cost anything from £1000 upwards. depending on spec of engine and how much work you wanna do?
Old Oct 4, 2007 | 12:09 PM
rs gez's Avatar
rs gez
car is £500 quid its a 88 xr3i converted to s2 rs turbo spec its white with half leather recaros e reg loads of chrome in engine bay chipped uprated acutator std turbo alloy rad but std intercooler, samcos
mot is til feb and tax til feb also roof is brand new and bodywork is showing very very little signs of rust there is no rust at all in the usual places ie battery tray, sills, inner wings etc
the big downside is this piston!!!! and i am not 100 on buying it if its gonna cost loads to do??? was gonna put engine in my cab (se500) ie rebuild it and transfer all the good bits over or just leave mine std as it is and do up the rst????
Old Oct 4, 2007 | 12:19 PM
scoooby slayer
personally if its as good as you say id have a go for £500
Old Oct 4, 2007 | 12:23 PM
saff_cossie's Avatar
saff_cossie
500 is good if the rest of the spec is in reasonable condition. You will easily see that if you break it.
I would say buy it (assuming it is otherwise in reasonable condition), if it does turn out to be too expensive, break it and make your money back
Old Oct 4, 2007 | 12:26 PM
rs gez's Avatar
rs gez
Dont want too break it lol too much hassle just want to fix it and put it back on road i think?????
i am thinking of stripping it all mywyself buying all the bits slowly and then getting some one to help me build it back up???
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
