problem with mondy st200?
Old Oct 2, 2007 | 01:48 PM
cossiecrew's Avatar
cossiecrew
Default problem with mondy st200?
when you rev it and let off the throttle sometime sticks and others it drops straight away any ideas its not the cable
Old Oct 2, 2007 | 03:36 PM
Dont these engines have a duel inlet manifold on them. Ive heard sometimes these stick. Do you know if you have an idle speed control valve on. I know the 16v zetecs do but im not to sure about the v6.
Old Oct 3, 2007 | 09:30 AM
bookwyse's Avatar
bookwyse
Its called 'Throttle Hang' and is easily fixed by placing a cooper cap in the pipe that goes from the bellows to the Idle COntrol Valve. This cap needs to be drilled with a hole between 3 and 7mm to allow the air through. I would start with a 4mm hole and increase it until the revs drop freely.
The caps themselves cost around 17p from any good diy place and are the ones used for blanking off copper water pipes.
Any other problems pop along to www.southeastcarclub.com and I will be able to help.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
