cleaning alloy wheels
Old Oct 1, 2007 | 01:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Default cleaning alloy wheels
the alloys on my impreza are absolutely filthy on the back - they look as if they have never been taken off and cleaned and you can't clean that bit of the rim on the car due to the brakes
the front faces are mint, it's the inner edge of the rim that you see through the spokes if you know what i mean
i have been scrubbing them with a nail brush and truck clean for 2 days now and it is not shifting the thick black layer of crud on there. i have also tried toilet descaler which works very slowly
have also tried white spirit but it does not touch it
any recomendations on what to use please if anyone has encountered the same problem?
Old Oct 22, 2011 | 08:18 PM
jammerrs's Avatar
jammerrs
I'm having exactly this problem, anyone got any advise?
It laughs in the face of alloy wheel cleaner (admittly my dad bought some wilko value stuff, dads ehy) and brake cleaner, would some wonder wheels really be that much better? I still can't see it shifting.....
Where can I buy neat acid?
Old Oct 22, 2011 | 08:24 PM
jamesXXX's Avatar
jamesXXX
Autosmart treble x is the nearest thing to neat acid that you can buy, without buying in bulk nowadays, i use it on the inside of my truck wheels, it will take shit off a blanket!!
Cost is about Ł9 plus the VAT for 5 litres
Old Oct 22, 2011 | 08:43 PM
jammerrs's Avatar
jammerrs
That sounds like the right sorta stuff cheers
Old Oct 22, 2011 | 08:44 PM
12340987's Avatar
12340987
T Cut worked on mine?
Old Oct 22, 2011 | 08:45 PM
Retro Al's Avatar
Retro Al
RWD IS KING
This works a treat on baked on brake dust,it will need a few applications http://www.polishedbliss.co.uk/acata...decon-gel.html that and some billberry wheel cleaner will sort it out,but like i said its a long process,a decent stiff brush will help on the inners aswell
Old Oct 22, 2011 | 08:49 PM
jammerrs's Avatar
jammerrs
This is proper baked on shit :/, like a matt black coating all over it
Old Oct 22, 2011 | 09:05 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Bilberry wheel cleaner is the bollocks.
I'mm not sure how it'll work on such caked on shite but it makes mince meat of day to day dust.
Old Oct 22, 2011 | 09:09 PM
jammerrs's Avatar
jammerrs
The faces are really good tbh, well good enough for what they are, cleaned and polished and only have 1 or 2 bits that have marks on.
There 7 or 8 years old and this is there first clean for the inside
Old Oct 22, 2011 | 09:13 PM
RichieST's Avatar
RichieST
I put that bilberry stuff in my pressure washer bottle thing, spray it on at low pressure, let it sit for a bit then blast again at high pressure, then finish with a rinse of clean water. Works a treat!
Old Oct 22, 2011 | 10:17 PM
12340987's Avatar
12340987
I was a little confused by what you ment, but if you are doing the inside face of the wheel, where basically taking the wheel off the car is the easiest way of doing it, id probably use 1500 grit wet and dry and flat them back and then re lacquer the insides if its that bad.
Old Oct 22, 2011 | 10:27 PM
phil_rs's Avatar
phil_rs
yam yammer
I've used wolf decon gel which works ok but I find using a clay bar removes contaminants from wheels better than anything IME
SmudgerByName
52
Jul 28, 2016 06:14 PM
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
mint_s2
Sep 2, 2015 08:58 AM
borboyous
Aug 22, 2015 11:17 AM
cossynut2
Aug 19, 2015 11:29 AM
