transit tdci
Old Oct 1, 2007 | 12:53 PM
davecosworth's Avatar
davecosworth
IM BACK
Default transit tdci
can any one tell me how to bleed the fuel system on a ford transit 51 plate 2.4 tdci, just fitted a new engine and it wont start have checked the system for faults using a snap on scanner i think the fuel isnt getting to the injectors, thanks dave
Old Oct 1, 2007 | 04:49 PM
mick's Avatar
mick
are you using the original fuel pump??? the ecu/ diesel pump need to be synchronised other wise it doesn't work, ford wants Ł110+vat for the privalige.............
Old Oct 2, 2007 | 12:42 PM
foreigneRS's Avatar
foreigneRS
Testing the future
these are now very complex pieces of kit. not only does the ecu need linking to the PATS immobiliser, but things like the injectors need matching up to the ecu and all sorts
Old Oct 3, 2007 | 08:18 AM
Spanthefestaman's Avatar
Spanthefestaman
I know that on the focus's and anything with that engine that there is like an 11 digit number that has to be programmed to the ecu. But i dont think that it is the same for the transit. As for bleeding them they are a nightmare. You have to crack all four pipes at the injectors and crank it over but they are very stubborn. I know its naughty but at work if we get one that wont go we use easy start.
Also make sure that the fuel filter is full. Just take the filter off and fill it with diesel.
Although as above i do think that the fuel pump has to be programmed to the ecu and so on.
Old Sep 18, 2012 | 06:57 AM
errol_e's Avatar
errol_e
hi dave do you have your old engine if so you can remove the ecu from the pump and put it on the engine you bought then you dont have to program the pump or you have to now get the pump programed to the ecu
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
