i want to take the waxol of the floor
as above iwant to paint the floor so what do i use primmer ,stonechip ,then top coat ,do i need to rust treat it before i primmer it plus woul you do it in this weather as the car of the road now or would you wait to the weather warm up
I used gunk to clean under mine up, seemed to work quite well, was very hard work though.
Then I used Epoxy Mastic 121 and painted on top of this.
http://www.rust.co.uk/filestore/rustbook.pdf
I painted mine on by hand and it came up very well
And thank you
Don't fancy doing another sorry
http://rust.co.uk/epoxy-mastic-more-info.cfm
http://rust.co.uk/filestore/epoxy.pdf
And I forgot, for cleaning up the underneath, you could try what I regret not thinking of - Try power washing it before you take it all to bits, it's worked for others
Personally as I don't have heating or permenant electric in my garage, if you're oing to do it now, I'd try to get it done sharpish before the winter sets in and it's just too cold to be working on it
Thats just my opinion though
Hi mate
Im doing this at the minute
looking at your signature i'd say you have an esc cos
click the link below my siggy and feel free to pm me mate, if you get stuck i'll pm you my number and try to answer any questions you may have. After doing this and learning and listening to friends and others who have done this i can answer most questions.
charlies is cool isnt it
Read the link and let me know mate
looking at your signature i'd say you have an esc cos charlies is cool isnt it
I had never done anything like that before either but I found it pretty easy after reading the manual
one more ? do u think a sand blaster or shot blast will get the floor clean of the waxol or just use a wire brush
Originally Posted by redrsmk5
Hi mate
hi people thanks for replys
but what scare me that i go by the work mannel and take the rear beam dif arms and shocks plus tank of and i cant get it back together as i never done nothing like this before but want to a good job on the floor plus i be doing it on my own or is it to much for one man on his own
you only need help when you come to drop the beam other wise its easy
If i were you i would not have the underside blasted or wire brushed, if your car has underseal on it in as good a condition as mine then leave it be, its awesome stuff once cleaned up and if its stood the test of time so far why remove it
The best thing for getting waxoil off the underneath is by using more waxoil, put some fresh waxoil on a cloth and rub at the area/areas where you want the old waxoil taken off.
The new waxoil seems to kind of melt/ dissolve the old stuff, keep turning the cloth over and it will come off. Then once all the old stuff is off then you can easily clean it.
Done this to a few cars now and i guarantee you this works.
charliesaff did u take the underseal of ur car and got it to the metal as i want to do what you did and use the epoxy mastic 121 as that looks like good stuff and i seen the results on ur car
155lee
Sep 6, 2016 11:10 AM
Orion_Gav
Sep 29, 2015 04:50 PM
